If printing quality problems occur or if you use your machine
in a dusty environment, you need to clean your machine
regularly to keep it in the best printing condition and use your
machine longer.
Cleaning the cabinet of the machine
with cleaning materials containing large amounts of alcohol, solvents, or
other strong substances can discolor or distort the cabinet.
If your machine or the surrounding area is contaminated
with toner, we recommend you use a cloth or tissue dampened
with water to clean it. If you use a vacuum cleaner, toner
blows in the air and might be harmful to you.
During the printing process, paper, toner, and
dust particles can accumulate inside the machine. This
buildup can cause print quality problems, such as toner specks
or smearing. Cleaning the inside of the machine clears
and reduces these problems.
Clean the machine cabinet with a soft, lint-free
cloth. Dampen the cloth slightly with water, but
be careful not to let any water drip onto or into the machine.
specks or something. Cleaning the inside of the machine
clears and reduces these problems.
To prevent damage to the toner cartidge, do
not expose it to light for more than a few minutes. Cover
it with a piece of paper, if necessary.
Do not touch the green area of the toner cartridge. Use
the handle on the cartridge to avoid touching this area.
Use a dry lint free cloth when cleaning the inside
of the machine, be careful not to damage the transfer roller
or any other inside parts. Do not use solvents such as
benzene or thinner. Printing quality problems can occur
and cause damage to the machine.
Use a dry lint-free cloth
to clean the machine.
Turn the machine off and unplug the power cord. Wait
for the machine to cool down. If your machine has a power
switch, turn the power switch off before cleaning the machine.
Before opening the front cover, close
the output support first.
Illustrations on this user’s guide may
differ from your machine depending on its options or models. Check
your machine type (see Machine overview).
Cleaning the pickup roller
Before opening the
front cover, close the output support first.
switch, turn the power switch before cleaning the machine.
Keeping the scan unit clean helps ensure the best possible
copies. We suggest that you clean the scan unit at the
start of each day and during the day as needed.
power cord. Wait for the machine to cool down. If
your machine has a power switch, turn the power switch
Slightly dampen a soft, lint-free
cloth or paper towel with water.
Lift and open the scanner lid.
Wipe the surface of the scanner glass until it is clean
and dry.
Wipe the underside of the scanner lid and white sheet
until it is clean and dry.
Close the scanner lid.
